Community Member
unity license
After i physically installed the unity express module in the router i typed service-engine 1/0 session command.From there i need to install the cue-vm-license_12mbx_ccm_2.3.4.pkg package.
What command is required ?
Bronze
Re: unity license
What version of Unity are you using?
Community Member
Re: unity license
first of all you must upload the license file in a ftp server, then follow the procedure
e.g.
AIM>software install clean url ftp://192.168.0.1/cue-vm-license_50mbx_cme_2.3.2.pkg
in this case is a anoymous ftp no user and pass required..
Re: unity license
all the information is already on CCO, please try searching within cisco.com for the information you need or within netpro, be proactive
Upgrading or Downgrading the Cisco Unity Express License in the Same Version
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_0/installation/guide/upg_3lic.html
Link to get the license. You can download either 25 or 50 license but make sure you get the cme file not ccm. Example:
cue-vm-25-license.1.1.2.cme.pkg
http://www.cisco.com/cgi-bin/tablebuild.pl/cue-netmodule
java
if this helps, please rate
java
www.cisco.com/go/pdi
126
