09-03-2014 11:18 PM - edited 03-17-2019 12:01 AM
In a scenario we are using BE6K with 700 users,we have ordered bundle CUWL-25 licenses Enhanced UCL-675,as i know unity connection comes by default 24 ports...my question wether all the 700 users can acess the voicemail with this existing licenses,are i need to purchase any additional licenses ...clarify me
09-04-2014 01:44 AM
Hi Siva,
CUWL Standard and Professional comes by default for unity connection.
for others [UCL Enhanced/Enhanced Plus], it is add on and must be ordered separately.
regds,
aman
09-04-2014 01:56 AM
As i seen in docs,enhanced licenses have the feature of voice mail.
09-04-2014 02:01 AM
Hi Siva,
Just refer the link and Table 1
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-communications-licensing/product_solution_overview0900aecd806cc7a4.html
regds,
aman
09-04-2014 02:10 AM
So in this case we need to go for CUWL standard!!!
09-04-2014 02:13 AM
If u are placing the fresh order, then , go for at least CUWL Standard for Voice mail facility else for existing UCLs , you need to place separate order.
regds,
aman
09-04-2014 02:42 AM
We don't have UCSS/ESW contract,as u told without that i cannot migrate the licenses from UNITY.,How can i seperately order is there any partnumber?
09-04-2014 02:53 AM
Hi Siva,
I can share the PArt Code but suggest speaking to your Cisco Account Manager to get clarity on my mentioned part codes as well.
CUWL-STD-K9 |
UTY2UCXN-MIG-UWL |
regds,
aman
09-04-2014 03:05 AM
Dear Aman,
Sure i will speak,
Clarify my queries.,
1).Is it possible through LCU tool we can generate a report in CUC?
2) In case during migration if all users have voicemail functionality can i get CUWL standart licenses?
3) As you told UCSS/ESW contract required for migration license & upgradation.,without this manually can i get the licenses,since i am moving to UCS platform.
3) I have used the part number R-CBE6K-K9 ,,,ordered enchance licenses around 300 ,so instead of Enhanced i need to order UWL standard,shall i use the same partnumber.
09-04-2014 03:28 AM
To answer your queries:
1).Is it possible through LCU tool we can generate a report in CUC?LCU can be used for CUCM only for migrating DLU to UCL type.
2) In case during migration if all users have voicemail functionality can i get CUWL standart licenses?I believe you would get Voice mail licenses for all users. The same would depend on Phone models being used and also, the part codes would be different
for upgrade Basic 6921 user , part code would be BE6K-BAS-UPG
for upgrade Enhanced 6945 user , part code would be BE6K-ENH-UPG
for upgrade Basic Voice mail license BE6K-VM-UPG
3) As you told UCSS/ESW contract required for migration license & upgradation.,without this manually can i get the licenses,since i am moving to UCS platform. No.You need to order Migration or have UCSS contract
3) I have used the part number R-CBE6K-K9 ,,,ordered enchance licenses around 300 ,so instead of Enhanced i need to order UWL standard,shall i use the same partnumber.Part codes would be different
Do speak to Cisco AM.
regds,
aman
