05-11-2008 10:05 AM - edited 03-15-2019 10:35 AM
I would like to re-run this but if I run the Unity Install it won't let me run without reinstalling unity. Where is the .exe for the wizard located so I can run it please.
Chad
Solved! Go to Solution.
05-11-2008 11:22 AM
Hi Chad,
Good question! Can you try this;
Run the Message Store Config Wizard through ...\CommServer\ConfigurationSetup\Setup.exe.
http://www.cisco.com/application/pdf/paws/42945/unity-sa-trblshoot-guide.pdf
Hope this helps!
Rob
05-11-2008 11:22 AM
Hi Chad,
Hope this helps!
Rob
05-11-2008 11:50 AM
Good stuff..
Chad
05-11-2008 12:10 PM
Hi Chad,
You are most welcome!
Take care,
Rob
