Unity Messages - listening the last messages
Hello All,
I have a customers that has about 200 messages in his voice mail box, he need to read the last messages (maybe delete teh rest), is there any options?
Cisco Unity 4.2 Build 4.2(1)
Please advise
regards
Andres
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Unity Messages - listening the last messages
Hi Andres,
If your Cisco Unity version is 4.x or 5.x, complete this procedure:
Log into the Unity Administration Page, and click Subscribers.
Select the subscriber that needs to be modified. Then, click Conversation.
Select the New Message type that needs to be played first and click Move Up. Repeat similarly for the Saved Message. The order of playback can be changed when you choose Oldest first or Newest first from the drop down menu and click the Save icon.
From this good doc;
Change Voice Message Order from Cisco Unity
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_configuration_example09186a00809c4663.shtml
Hope this helps!
Rob
Hi Andres,
From this good doc;
Hope this helps!
Rob
thankyouverymuch Rob!!
Hi Rob
Sorry disturb you
Do you know how delete all the messages to an user? he has around 200 messages from november of 2007
Andres
I'd like to know this too.
Hi Andres/Mark,
No worries :)
To Manage subscriber messages, this is probably an excellent choice;
Message Store Manager
The Cisco Unity Message Store Manager (MSM) allows you to perform several routine message store management tasks with a single tool. MSM Agents, defined to include a selectable set of subscribers, can generate message demographic reports, archive messages, delete messages, or set subscriber properties, all according to configurable schedules.
From the Great Unity Tools;
http://www.ciscounitytools.com/App_MSM.htm
Hope this helps!
Rob
Thanks Rob,
In my case, the unity is not integrated with exchange or lotus, it saving the messages locally. Do you know if this works anyway for removed messages of suscribers?
Hi Andres,
This just means the Exchange mailstore is "on-box" not external. You should still be able to use the MSM Tool :)
Cheers!
Rob
thanks a lot!! have a nice one
168
