Unity Multi-tennant
Jeffrey Knuckle
If a Unity 5.x server has two companies (A & B) If a caller calls company A, is it possible to prevent that caller from dialing a valid extension in Company B (from a Call Handler or mailbox greeting) but allow the caller to dial extensions in company A?
Jaime Valencia
unfortunately since you cannot choose the restrictions tables per company, call handlers will share the same restrictions/permissions
java
if this helps, please rate
java
Adam Thompson
Level 4
Level 4
If you have the users in the two companies seperated into different classes of service, you should be able to define directory handlers to only search based on a specific class of service.
This will allow you to seperate what extensions can be dialed if a caller decides they want to dial an extension from a call handler or mailbox.
Thanks for the responses.
I will try COS approach and see if it works.
as far as i can remember call handlers do not have COS settings
java
java
