09-04-2008 04:44 AM - edited 03-15-2019 01:02 PM
Hi all,
Is there a way of creating a unity account that just plays a recording and doesn't allow callers to leave messages?
Jamie
Solved! Go to Solution.
09-04-2008 04:55 AM
Hi Jamie,
On a Standard Subscriber mailbox you can just tweak the After Greeting Setting to say Goodbye or Hang up. I would go with Goodbye :) By doing this the Mailbox will no longer accept messages.
After Greeting
Indicate the action that Cisco Unity performs after the greeting plays:
Take Message - Cisco Unity records a message from the caller. Click the Take Message link to view the Messages page.
**Say Good-Bye - Cisco Unity plays a brief good-bye, and the call is disconnected. Click the Say Good-Bye link to view the Good-Bye call handler.
Send Caller To - Cisco Unity sends the call to the destination that you select:
Call Handler - Sends the call to the call handler that you select.
Directory Handler - Sends the call to directory assistance.
Greetings Administrator - Sends the call to a conversation for changing call handler greetings over the phone.
**Hang Up - Disconnects the call. Use carefully; unexpected hang-ups can appear rude to callers.
Interview Handler - Sends the call to the interview handler that you select.
Sign-In - Sends the call to the subscriber logon conversation.
Subscriber - Sends the call to the subscriber that you select.
Hope this helps!
Rob
09-04-2008 04:55 AM
Hi Jamie,
After Greeting
Hope this helps!
Rob
09-04-2008 07:30 AM
Hi Rob
hope evrything is going well with you :)
as long as this post about unity i have thing wondering about it
as we have addressed before issues with unity that somtimes need CTI with call routing rule to handel a call cominf from forwarded call and send it the VM of the last number in CF
ny question is if i wanna match a call forwarded from CTI to the unity VM thorugh call routing rule thorugh calling number or called number ?
thank you
Marwan
09-04-2008 08:13 AM
Hi Marwan,
Life is great! Hopefully with you as well :)
Routing Rules are based on DNIS (I believe)The full dialed number that Unity sees incoming.
Hope this helps!
Rob
09-04-2008 04:49 PM
Hi Rob
thanks for ur answer :)
but i ma wondering because there is two rules forwaded and dircte
and on the direct there is the ability to match on called DNIS or calling ANI so if the call forwaded from CTI with CFA to VM profile and we wanna match it which option considered right in this case?
i know if we have direct access to the unity DID this case we could u se both called and calling or any one of them !
sorry for this complexsity :) !!
thanks
Marwan
09-04-2008 09:45 AM
Wouldn't it be better to use a Call Handler for this so it doesn't take up a license? You can get the same features, call comes in, plays a prompt, then hangs up.
