07-28-2008 01:30 PM - edited 03-15-2019 12:14 PM
I have Unity 5.1(0) and although I created a call Handler to distribute voicemails for specific recipients, I cannot change the "message recipient" field in the Messages area to a Public Distribution List I created. No matter what I do, it stays the "all subscribers - <server name>" selection. It takes the change, but when I come back to the window, it defaults to this PDL.
Can someone please assist ASAP?
07-28-2008 01:35 PM
Just an update. I think I found a bug: CSCsk06752 that exactly describes my issue. I will install the update and report back my findings...
Ed
12-17-2008 07:04 AM
I installed a pair of Unity 5.X with UM offbox and had the exact same issue. I hit this bug. I want to add that, the work around until you apply the ES is to:
Use the Bulk Edit Tool in Cisco Unity Tools Depot to make the change. In the "Messages" tab select messsage recipient and then select your subscriber. This works great!
Please rate this post.
Kramer
03-04-2009 02:43 PM
I believe I am running into the same issue. Did the ES resolve the issue?
Thanks!
