unity on vmware
please a try to install unity connection on Vmware version 8 but the wizard installation just shows me cucm install but when i put the CD on physical server it  appears
regards
unity on vmware
Hello, maybe you.re using wrong OVA files, use the correct files for CUC.
Vmware version 8? I think that the vmware version sopported for the hardware it's version 5.
Hall of Fame Super Silver
unity on vmware
That means you deployed incorrect OVA template and hardware settings dont match and hardware detection gives you no option for Unity.
Chris
unity on vmware
I uplaod
CUC_5000_user_v1.0_vmv7.ova version and i put DVD of CUC 9.1 but it deosn't appear just CUCM and it shows me down unsopported install
best regards
unity on vmware
can you please Some one provide me with URL of valide ova version 9.1 OR 8.5 that i can used to install a CUC on Vmware v8
Best Regard
unity on vmware
144
