Community Member
Unity points to exchange server
Can someone tell me where Unity, in a Unified Messaging environment, points to exchange, and how I would go about changing that to a new exchange server?
Re: Unity points to exchange server
Usually partner exchange information is setup during the installation wizard. I guess there is another way of changing the exchange partner server information is "Run the Permissions wizard" from the Unity tools depot and follow the prompts until you reach a point whether you want to change the exchange server.
Hope this helps
Bronze
Check the documentation below for specific version instructions but you will probably have to re-run the mailbox configuration in add/remove programs to re-home to a different exchange partner server.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/42/upgrade/guide/ex/ru_060.html
214
