Community Member
Unity port busy error on Application event
We are running Unity4.0(5), in the application event I am getting the below mentioned error:
EVT_AVMIUMSG_PORT_STUCK
Source: CiscoUnity_Miu
Message: Port %1 has been busy since %2. The system threshold is %3 minutes, indicating that this port is currently unavailable and may be unable to handle further calls.
Any suggestion?
1 REPLY
Re: Unity port busy error on Application event
It could be that
an RTP stream is still active to that port. It is also possible that the port didn't
correctly disconnect after a call was completed. You can try to reset the port from the
CallManager, but in most instances a reboot of Unity is required to clear the port.
197
