Community Member
Unity port cannot able to add
  Port limit reached to its maximum allowed configuration for its hardware.
  Voice ports can be configured up-to a maximum of 8 on ucs-unity-1.
  Found 8 Port(s)
Should i need any additional license for voicemail ports?
how many ports it support  by default in UC9?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Siva,
I'll just add a quick note to the good tips from Java (+5)
Check out this info;
https://supportforums.cisco.com/community/netpro/collaboration-voice-video/unified-comm-application/blog/2013/04/17/unity-connection-911-unable-to-create-more-than-8-ports
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
That depends on the HW of the MCS/OVA you're using, if you reach the limit, there's nothing to do, unless you upgrade to the next MCS/OVA size.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
Hi Jaime,
Currently UC running on  BE6K Ucs 220 m3 server.running version 9.1
so you mean its not licensing issue.?
Its related to hardware issue or compatibilty ?
The OVA size you use, determines how many ports you can configure. The last link from Rob's answer explains this as well.
java
java
Hi Siva,
Cheers!
Rob
- OneRepublic
Community Member
Thanks for your valuable information,i am facing the same thing
115
