Silver
Unity port number shown as from
I have creted several Unity callhandlers and all works fine.
When the callmanager receives the call is send it to a CTI route point with CFA set to voice mail pilot
On the Unity server the system will play a prompt and then transfers the call to a hunt pilot with some line groups.
The issue is that when a call arrives on the phone, it displays the original caller ID and under it the message "From 5000" And 500 is the voice port.
Is there a way to make the voice port transparent? So it won't show up on the phone.
When making a similar configuration on IPCC, the CTI ports do not show up.
CM 4.1.3 Unity 8.0.3
JH
  • IP Telephony
Re: Unity port number shown as from
Unfortunately this is solved in 4.2(3) but not in 4.1(x)
4.2(3) and 6.X and above have the following service parameter to do what you want:
Display Original Calling Number on Transfer from Cisco Unity
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Silver
In my office we are using CM 6.1 and Unity 5.0
On this system I developed some IVR for my customer thatr is using CM 4.1 and Unity 8 (CM 4 will be upgraded to 8 finaly)
The default for the parameter you are revering to is 'false' meaning it should display the port number.
But on my configuration, whatever I put (false or true) I never see the VM port number on the phone, only the calling party number.
This week I shall go to my customer to see exactly what is displayed on the phone.
In my office I can't get the VM port on my phone, only the calling number.
Thanks for your help,
Jan
150
