Unity post greeting delay
            I have a standard greeting on our Unity 8.6 setup but as soon as the greeting is finished it goes immediately to transfer to the operator, which is what I want but I want at least a 6 second delay before the transfer happens.
     I tried changing the "Delay between Re-prompts" field as some other posts suggested but it seems to have no effect at all.  Ive also manually created a greeting with 6 seconds of silence at the end but unity is SO helpful that it automatically chops the silence off the WAV file for me after i save it.
My current setup is, outside dialer calls 6700, gets "standard greeting", after the greeting goes to call handler "Operator" which is the operator extension.
Is there somehting Ive missed or should this work?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi there,
The post greeting delay won't kick in unless you set the times
to reprompt to at least 1 so that may not be what you want.
You can use ATM from the great suite of Unity Tools to insert silence
into a recorded greeting as well. I have tested this and it works well
http://www.ciscounitytools.com/Applications/CxN/ATM/Help/ConnectionAudiotextManager.htm
This is a fantastic tool as are all the tools from Jeff & his team.
Cheers!
Rob
"When it comes to luck you make your own  "
- Springsteen
Hi there,
Cheers!
Rob
- Springsteen
Re: Unity post greeting delay
Thanks Ill try it, not sure why it would matter what audio editing tool I use.  I just assume its a WAV file regardless but ill give it shot anyway.
There is a special feature within the tool that will actually
insert x - seconds of silence that will be respected by CUC.
Believe me it works
Cheers!
Rob
- Springsteen
Seems like overkill just to do such a small thing but ATM worked.
217
