Unity Reporting Tools
I am wondering if there is a reporting tool that will identify all of the Caller Inputs per voicemail box. We are finding that our system was setup with the Operator as the "0"-out, but we do not monitor that voicemail box. We have individual operators per building. I just wonder if there is an easy way to gather this information rather than individually touching 700 voicemail accounts.
Thank you for your help.
Laurel
  • IP Telephony
There's a subscriber dump info tool you can use.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thank you for your response. Unfortunately when I click on the link I get a message that states I am going to a forbidden page. I cannot figure out how to get to it.
Re: Unity Reporting Tools
That goes into every post, its not specifically for you, and you need to be a partner to reach the site, look at the tools depot online
java
Hall of Fame Super Red
Hi Laurel,
+5 to Java for this good info. Here's a link to the great tool;
Connection User Data Dump
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/Help/UserDataDump.htm
Cheers!
Rob
"When it comes to luck you make your own  "
- Springsteen
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
I think this just might do it! Thank you so much!!
235
