Unity: Restrict dialing certain ext number from Handler
I am running Unity 4.2, and have many remote sites. All remote sites' incoming main line is answered by a different Unity call handler.
I have a certain extension that I want to restrict these remote sites from dialing out of the handler. Any suggestions?
Re: Unity: Restrict dialing certain ext number from Handler
Unity has no means to do this, this feature is only on CUC 7.X with the CSS and partitions configs which determine what a call handler (among others) can reach.
i assume the number you mention is already a subscriber so it's not possible, if it's a DN in CUCM then modifying the CSS for VM ports would prevent this but for ALL users.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks, that confirmed my suspicion.
Hi Java
How do I  configure this feature in CUCM 7?
Because  I have some branches that can not appear on the screen of the user,  there is no way to do this gives me the details please.
Cheers Bruno Rangel Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers .
Not sure what you're asking, this is for Unity and how to restrict dialing from a CH.
This is not related to CUCM.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Sorry  if I was not clear I will reformulate my question and open a new  discussion
156
