Unity Ringing
When calling into our system currently, the system answers with the auto-attendant, then when a caller enters an extension, the extension rings, however it is one long ring that lasts for about 20 seconds. Where would you think to start looking at the issue? CUCM or Unity?
Unity Ringing
What are CUCM & Unity versions ?
GP.
Unity Ringing
CUCM 8.0.2 and Unity 7.0(2)
Unity Ringing
If it's supervised transfer I would check the port status monitor in Unity as a start, if release to switch, I'd check CUCM
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Re: Unity Ringing
It is release to switch. This just started happening. Shoudl I try to restart the CUCM services and then see what we get from there? This is a very strange thing. Sometimes we get one continous ring, sometimes we get a single ring then nothing, but the user being called still has a ringing phone even though there is silence on the callers side.
222
