Unity Subscriber Addition Problem
Please take a look at the attached file. Any idea why this problem is occuring?? This is new unity installation (4.2.1) on win 2003 platform.
Sheeraz
Re: Unity Subscriber Addition Problem
Probably something you would address with TAC but I would ask this is Voicemail only or Unified. If unified, are you able to import AD users. I am sure you would have run permissions wizard but may want to start by review the app log for relevant errors. I know little help but maybe a start. -Adam
This is VM only. I have checked all the logs and everything appears fine. All ports are registered with CCM, CCM is accessing VM menu as well but only when the subscribers are added to the Unity, problem appears.
Unity is very specific on installation steps. Did a quick search on your error and not much but sounds inidicative of a problem with your browser. Does the same happen if you try to add a subscriber from a remote workstation ? Does it work correctly from unity console?
Microsoft Internet Explorer Script Error: No such interface supported
Microsoft Internet Explorer displays a Script Error dialog box that includes the error message: ?No such
interface supported.?
Command-Line Interface Errors
These errors may occur while using the menu-based command-line interface from a console or Telnet
session.
Table A-8 Microsoft Internet Explorer Script Error
Problem Possible cause Solution
While using a Manager function
that opens another browser
window (such as Save Needed,
Help, Software Update, etc.),
Internet Explorer cannot open
the window and displays the
error dialog box.
A bug in the Internet Explorer
JavaScript interpreter.
1. Click No on the error dialog
box.
2. Log out of the Manager.
3. Close Internet Explorer.
4. Reinstall Internet Explorer.
126
