Community Member
Unity Subscriber caller input
Unity 4.1.
Under subscriber...caller input programming.
On Key 1 I program for alternate contact number ex:7777
Then
On Key 2 I program for alternate contact number ex:8888
For some reason when i go back and check Key 1, the alternate contact number changed from what I programmed 7777 to what I programmed for Key 2 8888.  The system will not allow me to apply 2 different alternate contact numbers.
Is there a setting or restriction that I am unaware of?
Thanks!
1 REPLY
Re: Unity Subscriber caller input
You can only specify 1 alternate caller input number for a Subscriber.
Hailey
Please rate helpful posts!
202
