Unity Type
is there a field anywhere that will tell you if unity is set up in VMO or full UM
I have a server that has full UM licences but don't think they are using it as such
Hall of Fame Super Silver
Re: Unity Type
You can simply see where their mailbox is, if it's the same as their email then they are using it as UM, if the mailbox is something other than the email mailbox than it' VMO.
Chris
Re: Unity Type
Another way to check is to look at the licensing in unity admin. It will tell you license available and use
Re: Unity Type
Looking at licensing will only tell you how the user was configured, does not mean that the user is actually used as UM or VMO, it's just a setting in COS. Also, Unity 4.2 and below did not have separation for UM and VMO.
HTH,
Chris
Re: Unity Type
Thanks Chris. Its been quite some time since I have dealt with 4.2. I did not realize that it didn't specify.
Re: Unity Type
Michael,
You work for Meridian IT in Deerfiled?
Say hello to Christian, Craig, and Todd from me :-)
Chris
109
