Community Member
Unity Upgrade
Hi, i'am planning to upgrade unity from 2.x to 7.x;
as the exchange server is upgraded to 2007 , and is not supported by unity 2.x
is there any way for 2.x to support exchange 2007. Thank you.
1 ACCEPTED SOLUTION
Re: Unity Upgrade
no, support for Exchange 2007 requires unity 5.X or 7.X, no other releases can support it.
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
Re: Unity Upgrade
java
java
153
