Silver
Unity user's web access address
Hello All,
I can't remember what's the web address that we give to users in order to handle their voicemails. I am looking for the equivalant address of <CCM IP address/ccmuser> in unity. I have used it 100 times but can't remember it. We are unig unity 4.2.
MK
Hall of Fame Super Red
Re: Unity user's web access address
Hi MK,
Thanks to Christopher;
http:///CiscoPCA
Hope this helps!
Rob
Are you referring Cisco Personal Communications Assistant
http://
Silver
Thanks guys,
What username and password is used for login?
Thanks again,
MK
Assuming you have enough licenses. If you have integrated your unity with AD, please try using your AD credentials.
That should work
Silver
The voice mail is not integrated with the existing exchange therefore there's no AD credentials. This is a voice only implementation.
MK
Start>>>>Programs>>>>>Microsoft Exchange>>>>>Active Directory Users and computers, and find the alias or name you want to log in with. Right click on that name and reset password. Then log in with that alias and the new password
Silver
Thanks Mat, it worked
Do I need to reset the password for everbody or there's somewhere that I can change it once for all?
Thanks again,
MK
There is a setting i think in the subscriber template that sets that password. you may want to check there.
582
