Community Member
Unity v4 to v5, what's backed up?
Hello -
We are going to upgrade from Unity v4 to v5... Do call handlers and such get backed up? Is there a way to back these up? We have on-box VM, so I can use the exMerge tool to preserve the voice messages.
Thanks for the reply!
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Unity v4 to v5, what's backed up?
Hi Ben,
Yes, all Call Handler info will be migrated across doing an "In Place" upgrade.
Hope this helps!
Rob
you can look at all the stuff that is backed up at the DIRT help
http://www.ciscounitytools.com/HelpFiles/DiRT/index.html
What Data Is Saved
Most Unity data is saved in this process. This includes all subscriber data, call handlers, interviewers, voice names, greetings, passwords, switch configuration information, etc… optionally you can backup report data and in the case of an Exchange based system, subscriber messages as well. Only a few specific items and settings are not preserved during the restore process. See the next section for those.
NOTE: While switch configuration information stored in the switch.INI files is saved, it is not restored onto the system. The data is in the original backed up files in case TAC needs to get to it. Since switch configuration can and does change between back up and restore (i.e. when moving systems) the local switch configuration needs to be configured and will not be restored. UTIM configuration data stored in the database is NOT backed up or restored.
NOTE: In 4.1(1) and later, the passwords entered during the password hardening wizard on the new installation (the one you will be restoring over) are used for ALL subscriber templates that are restored. This is to ensure that passwords which may not have been "hard" on the backed up system do not cause failures in the AD/Exchange account creation process during restore.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Thanks! So I guess what I am looking for is if I upgrade from Unity 4.x to 5.x with on-box VM, all my call handlers and stuff will be saved during the migration process?
Hi Ben,
Hope this helps!
Rob
111
