Unity Voicemail only - changing domain name.
I have a Unity voicemail only solution. Exchange on box. Want to change the domain name on the unity server. Which means the domain controller, exchange etc are also affected by the change. What is the best way to proceed with changing the domain name with out having to reinstall the whole box.
Green
Re: Unity Voicemail only - changing domain name.
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_upgrade_guides_chapter09186a0080623595.html#wp1097725
To Rename a Cisco Unity Server or Move a Cisco Unity to Another Domain (Without Failover)
You need to reinstall it, otherwise you will get in trouble changing ALL references from regedit, DB, etc, which will 99% fail and you will encounter problems.
Jeff have already answered this query and obviously the best option is doing that, I dont know anyone which has succeded without using this method. Any reason for not reinstalling?
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddcc26b/0#selected_message
The server is not in production yet. So i do have the option to reinstall. I was only trying to avoid the number of steps involved in having to setup all this over again.
THanks.
132
