Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Unity voicemail time issue
Can you please advice how do you change the time on Unity voicemail? We are using cisco unity ver 5.0
TIA.
PF
Re: Unity voicemail time issue
Hello there,
It is not clear what exactly you are asking, but if you mean the timezone in which each Unity Subscriber (user) is in so that when they receive new messages the time that is stated is in relation to their location, then you can just go to the relevant user from the Unity Admin page, then select profile and under profile you have 'Time Zone', just change that setting to what you require and I believe this should work.
If of course you were speaking of something different, could you please elaborate?
John
John,
Thanks for your information. That was exactly what I was querieing.
Instead of changing profile at a time, can we do to it globally (control panel --> date/time)?
Does the Cisco Security agent need to be stopped before we stop the the unity service?
Thanks.
PF
Hi PF,
You can simply change the date/time and time zone in control panel and then restart Unity. I am pretty sure that CSA does not need to be stopped!
John
John,
Thanks very much.
PF
315
