Unity vs Unity Connection
We're trying to narrow down the pros and cons about these two products.
For an enterprise redundant design, which solution you would/would not prefer and why?
Thanks for your comments/inputs in advance.
Re: Unity vs Unity Connection
Unity Conn does not have failover yet.
The amount of subscribers to which you can scale to on both products are diff. (Unity is as high as 7500).
Thanks for the quick response.
Here's a good link to the Feature Comparison Matrix. A good place to start.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd806bfc37.html
Michael.
Thanks for the quick response. This was very good.
Hall of Fame Super Red
Hey Guys,
The feature sets are getting closer and closer with Unity and UC. This doc nicely encapsulates some of the differences. UC is not integrated with Exchange but can currently support up to 7,500 users (and this number is increasing - see below) Also, UC 7.0 supports Active-Active redundancy;
Cisco Unified Messaging Feature Comparison
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd806bfc37_ps5520_Products_Data_Sheet.html
Have a look at what is coming down the pipe for both systems:)
Unified Communications Applications: Unity Connection 7.0 EFT Opportunity
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbeeab0
Unified Communications Applications: Unity 7.0 EFT Opportunity
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbee2ac
Hope this helps!
Rob
Hello Again,
Where can get brief feature discriptions for the comparison page below?
The following are some of the topics that I would like to get a little bit info on.
Enterprise Deployment:
System networking/VPIM/AMIS/unityBridge
Telephone Environments:
Serial/Analog Integration
Security:
RSA Securre-ID 2-factor one-tiem PIN authentication interface
Call Transfer Feature:
Tranfer to Alternate contact num.
Administration:
Custom Key Mapping/Hospitality Integration
Fax:
Thanks again.
Fureya
470
