Unity vulnerabilities
Hello guys I have 2 unity servers (5.0) that a software has detected 4 and 5 level vulnerabilities on them. Both servers are running windows server 2003 with SP 1. Could it be an issue if I applied the recomended patches to them? .  And also we are pretending to upgrade the operating system from windows server 2003 SP 1 to windows server 2003 sp 2, do any body has done this, it is safe doing this 2 actions?
Thank you for your help.
1 REPLY
Re: Unity vulnerabilities
I would recommend using the Server Updates Wizard to install the necessary Microsoft updates. SUW installs the Microsoft updates that are approved and recommended for Windows, Exchange and SQL.
http://tools.cisco.com/support/downloads/go/ReleaseType.x?optPlat=&isPlatform=Y&mdfid=281063851&sftType=Microsoft+Updates+for+Cisco+Unity%2FUnity+Connection&treeName=Voice+and+Unified+Communications&modelName=Cisco+Unity+Version+5.0&mdfLevel=null&tre...
You can also take a look at the System Requirements doc for approved service packs. SP2 for Windows Server 2003 is approved and recommended.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/requirements/50cusysreq.html
If an update is not installed by SUW and not approved by Cisco, you install it at your own risk. It may not cause a problem, but if it does, Cisco will not support the product until this update is removed.
Hope this helps.
Brandon
172
