Unity4.2 empty deleted Voicemail
We are running Unity 4.2 (voicemail only)with Exchange2003 as the message store. When a user delete a voicemail, it goes to the delete item folder and I am trying to find a way to empty the deleted item folder automatically but it won't work. Any helps will be apprecaited.
Mark
Hall of Fame Super Red
Re: Unity4.2 empty deleted Voicemail
Hi Mark,
Have you checked out this good doc;
Configuring Cisco Unity to Automatically Delete Messages
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a00800d6824.shtml
Hope this helps!
Rob
Hi Rob,
Thanks for the quick reply. I had the document and followed the steps but it didn't help. Please see the attached jpg image. There are messages in the deleted item folder since 2008.
Mark
Hi Rob,
Quick question. What is the difference between "Move messages from inbox to Unity Dumpster" and "Move messages from Inbox to Deleted Items folder"? When a user delete a Voicemail, does it go "delete item folder" or does it go to "Unity Dumpster"?
Thanks in advance
Mark
165
