UNITYCN7-300USR license missed?
qilin zhang
Hi all,
Recently, we ordered a new Cisco unity connection 7.0 including the following items:
UNITYCN7-K9
UNITYCN7-300USR
MCS7825H3-K9-UCB1
But when I received the equipment, I can't find out the UNITYCN7-300USR PAK paper like CM device license used, just the UNITYCN7-K9 software and MCS server.
Did we missed this part?If not where can I find out the PAK paper so that I can register on CCO to download the license file?
Kirin
Afragoso2009
I am having the same problem ?
Did have a solution or not yet ?
Please answer
Very best Regards
I had same issue with a 4.2 Unity to Unity Connection 7.1.2. What I found was you are suppose to use the Unity licenses. There is actually a line on the license page that says something like "allow license from all vesions" The migration file sets this to yes.
There is a TAC case CSCTA07490..
As a side note I loved the instructions they were soo easy to follow.. sorry i couldnt resist...I found a ton of stuff that was missing or left allot of guesing.
