10-08-2010 08:25 AM - edited 03-16-2019 01:14 AM
I have a customer that forwards alot of emails to various UConn subscribers but does not like the fact that he has to dial 91 every time he wants to add another address. I looked all over the keymapping field to see if I can change that but cant find the option.
Ex. User checks messages and presses 5 to forward. User adds a pre-message then presses #. spells by name or number, adds the first address then is prompted to dial 91 to add additional addresses or press # to send.
We want to change the 91 option to a something else. Can this be changed and if so, where is the option?
Thanks.
10-08-2010 08:59 AM
Hi Edward,
Go to the User > Edit> Send message Settings > "Check" Continue Adding names after each Recipient
This will remove the 9-1 option after each name/extension is entered
Cheers!
Rob
10-08-2010 09:06 AM
Pefect, thanks!
