Community Member
UNIX timstamp on CDR of Voice Gateway
whether it is possible to generate unix timestamp in CDR on the Voice gateway.
I need this format for billing software, which download CDR from my voice gateway.
Voice GW is 2811 ISR router, and CUCM is v6
Green
Re: UNIX timstamp on CDR of Voice Gateway
For CUCM as you know we generate it epoch time if you are using MGCP you can get records from there, in case you are not using MGCP can you tell us which protocol and which SW you use to obtain the records?
Normally we use:
service timestamps command which does not have the option for unix afaik , but let us know how exactly you are obtaining the records so we can figure this one out.
Community Member
I use Cisco 2811 ISR router as H323 voice gateway and it generates the CDR, and sends them to an FTP on my billing server primary, and secondary to flash on router.
Primarily, I used the CDR directly from CUCM and it was satisfactory, but how we connect the Siemens PBX to the vgw, we need the cdr from the vgw, where CDR is different than the one from CUCM.
123
