Unknown Call in CCM 7
I need some guidance in how to handle unknown calls coming into the CCM 7. We currently have two PRI using an MGCP gateway. I was wondering if there is some sort of system that I can implement to reroute calls that come in with a caller ID of “ Private” or “Unknown Call”, so that they can be identified before they are patch in to the extension or number called.
1 ACCEPTED SOLUTION
Re: Unknown Call in CCM 7
Not with MGCP, you would need H323 to match calls with unknown CLID and either reject them or apply some translation to them.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
154
