Community Member
Unknown EEPROM cookie
I have a lab router with a VIC2-FXO and VIC2-FXS cards. Everything has worked just fine on it until the other day I blew the config away to start over with the lab. Now I cannot configure voice ports.
A show diag shows the voice cards but on the PVDM slot it now shows the following:
JSM_1740_VG#show diag
Slot 0:
        C1760 1FE VE 4SLOT DV Mainboard Port adapter, 5 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware Revision        : 3.0
        PCB Serial Number        : FOC07220T3X
        Part Number              : 73-7167-03
        Board Revision           : A0
        Fab Version              : 04
        Product (FRU) Number     : CISCO1760
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 03 16 41 03 00 C1 8B 46 4F 43 30 37 32
          0x10: 32 30 54 33 58 82 49 1B FF 03 42 41 30 02 04 FF
          0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Packet Voice DSP Module Slot 0:
        Not populated
        Packet Voice DSP Module Slot 1:
        VIC Slot 2:
        Dual FXO Voice Interface Card
        Hardware revision 1.1   Board revision K0
        Serial number     0029485045    Part number    800-02495-01
        FRU Part Number   VIC-2FXO=
        Test history      0x00          RMA number     00-00-00
        Connector type    WAN Module
        EEPROM format version 1
        0x20:   01 0D 01 01 01 C1 E7 F5 50 09 BF 01 00 00 00 00
        0x30:   A0 00 00 00 03 01 04 01 FF FF FF FF FF FF FF FF
        VIC Slot 3:
        Dual FXS Voice Interface Card
        Hardware revision 1.1   Board revision B0
        Serial number     0025082140    Part number    800-02493-02
        FRU Part Number   VIC-2FXS=
        0x20:   01 0E 01 01 01 7E B9 1C 50 09 BD 02 00 00 00 00
        0x30:   58 00 00 00 01 03 12 01 FF FF FF FF FF FF FF FF
Has anyone seen this before?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Try reseating the pvdm modules.
Community Member
Looks like the slot went bad on the router. When I moved it to Slot 0 it came up, reseating in slot 1 gave the same error.
431
