09-04-2007 08:40 AM - edited 03-14-2019 11:22 PM
Hi all
Im a newbie when it comes to all this phone gubbins so forgive my lameness..
We've got a UC520 running CME connected to our ISDN via a BRI connection. All working great. Apart from.. when i call into the office from my mobile, I get Unknown Number appearing on my 7941.
In short, how do I get the calling nuber displayed on the phones rather than the cryptic Unknown Number?
Cheers
Solved! Go to Solution.
09-05-2007 06:42 AM
You might want to also check with your provider to find out if they support callerid or if you are set up to have it on your circuit.
09-04-2007 08:48 AM
Number should appear without any special command. Please send output of "debug isdn q931" taken with "term mon" first.
09-05-2007 01:06 AM
09-05-2007 06:42 AM
09-05-2007 08:19 AM
Well it seems that BT haven't enabled CLIP on our circuit so thats why we arn't getting any caller id's!
09-27-2007 02:54 PM
Looking at the debug, the calling number is not present only the called number... BT needs to fix it.
09-28-2007 05:55 AM
hmm.. not sure where to go now.. theres some posts saying that the number may well be chopped off by the telco.. your going with BT being at fault mate?
