unknown number
Hi there !
I have a SRST router connected to an Avaya pbx (qsig)
When a Avaya phone calls to a Cisco phone, the cisco phone does not show the extensio number... it shows "unknown number"...
How can I fix this ?
Thanks.
Andrei.
paolo bevilacqua
Take "debug isdn q931" with "term mon', post the output here.
Hi, sorry for taking so long to answer.
From 4240 (Avaya) to 5050 (Cisco)
.Mar 4 15:46:12.269: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x7176
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1839E
Preferred, Channel 30
Progress Ind i = 0x8183 - Origination address is non-ISDN
Called Party Number i = 0xA1, '5050'
Plan:ISDN, Type:National
Locking Shift to Codeset 6
Codeset 6 IE 0x28 i = 'Juan'
.Mar 4 15:46:12.929: ISDN Se1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xF176
Channel ID i = 0xA9839E
Exclusive, Channel 30
.Mar 4 15:46:12.953: ISDN Se1/0:15 Q931: TX -> ALERTING pd = 8 callref = 0xF176
Facility i = 0x9FAA06800100820100A116020101020101800E4F73636172204D617274696E657A
Progress Ind i = 0x8088 - In-band info or appropriate now available
.Mar 4 15:46:22.765: ISDN Se1/0:15 Q931: TX -> CONNECT pd = 8 callref = 0xF176
Facility i = 0x9FAA06800100820100A116020102020102800E4F73636172204D617274696E657A
Connected Number i = 0x0081, '5050'
.Mar 4 15:46:22.805: ISDN Se1/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x7176
.Mar 4 15:46:44.657: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x7176
Cause i = 0x8190 - Normal call clearing
.Mar 4 15:46:45.485: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0xF176
.Mar 4 15:46:45.497: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x7176
From 5050 (Cisco) to 4240 (Avaya)
.Mar 4 15:47:54.707: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0003
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9FAA06800100820100A116020101020100800E4F73636172204D617274696E657A
Calling Party Number i = 0x0080, '5050'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '4240'
.Mar 4 15:47:54.755: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8003
.Mar 4 15:47:54.775: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8003
Progress Ind i = 0x8188 - In-band info or appropriate now available
.Mar 4 15:48:22.967: ISDN Se1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8003
Progress Ind i = 0x8182 - Destination address is non-ISDN
.Mar 4 15:48:23.231: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0003
.Mar 4 15:48:32.907: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8003
.Mar 4 15:48:33.719: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x0003
.Mar 4 15:48:33.751: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8003
Thanks.
Andrei.
Hi, the avaya is not sending a calling number, so it's impossible for the cisco to present it.
If you want to see the number,you must ask the the avaya technician to configure so the calling number is sent.
