Unknown Reason code - CTI application failed to open provider
I am trying to connect my application to CCM 5.0.4.2000-1 using JTAPI and I am getting the following error. usually it means that username or password is wrong. I doublechecked the username, password, also the JTAPI library version and everything is correct. I also tried to find the description of the Reason code, but it seems to be an undocumented issue.
The application I am referring to is widely used with CCM 3.3, 4.1, 4.2 and 5.0, but I have never seen this Reason code. Anybody have some clue how to find out where the problem is?
kCtiProviderOpenFailure - CTI application failed to open provider
CTIconnectionId:4
Login User Id:callrec
Reason code.:-1932787595
IPAddress:10.6.2.52
App ID:Cisco CTIManager
Cluster ID:StandAloneCluster
Node ID:CMVM50
Thank you
Michal
  • IP Telephony
Silver
Re: Unknown Reason code - CTI application failed to open provide
Did you associate the CTI-RP with your JTAPI user? also try restarting the CTI Manager.
There is no CTI-RP. Application observes several IP phones, these are associated with the JTAPI user. I tried to restart CTI Manager several times, but it did not help.
Gold
The user that was created, is it an Application User or End User. This should be an Application user.
Well, I tried both, but I am still getting the same error. Which is strange, I think... :-(
Does the user have the proper settings to use CTI? The user must be in the User Group "CTI enabled".
/Martin
Yes, everything is set up correctly. We have another installations which work perfectly. But this one does not. I think the Reason code description could help us to find out the source of the problem...
502
