Community Member
Unlock Config CP-7960
I have several of these phones and the **# unlock config code does not work on them. There was another unlock config that I believe was 4 digits to unlock the phone. Can anyone help before they end up in the trash unnecessarily?
Everyone's tags (4)
Hall of Fame Super Gold
Try a factory reset.
If they are running a SIP firmware, **# will not work.
Press the settings key, then scroll down and see if there is an option "9 unlock config".
If you do not know the password, try cisco.
Community Member
This solution worked for me.
Hall of Fame Super Silver
Also, if this is CUCM 4+ you need to first press Settings before doing **#
HTH,
Chris
try the deault "cisco"
16980
