Unregister Unity from CCM
Does anyone knows what is the best practice to Unregister a Unity Secondary Server ver 4.2 from CCM 4.2.3?
Many thanks in advance,
Maddox
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Unregister Unity from CCM
Excellent, glad to be of assistance.
Please remember to rate all useful posts!
Chris
Silver
the simplest way is to use the depots tools that is installed on cisco unity server go to switch integrations u will find ur current sec server integrated with CCM just click on delete integration..
hth
please remember to rate helpful posts
/majdi
Make sure that you remove the Line Group(s) and Hunt Group, and voicemail ports referencing the secondary Unity in CallManager admin page.
HTH,
Chris
Dear All,
Thank you for your input.
Chris,
Yeah, this is the answer I was looking for.
Many thanks,
Maddox
Chris
99
