Unregistered FXS port in CME
I'm having trouble getting one of my clients' analog endpoints to register in CME.  There are at least another dozen SCCP analog devices configured and they all seem to work fine.  According to the debugs inbound calls are routing appropriately but because the SCCP endpoint isn't registered the port isn't ringing.  I seem to have spare DSPs for the port to use.  Any ideas?  They're running 12.4(22)T and the analog connectivity is provided by an EVM-HD-8FXS/DID with EM-HDA-8FXS daughter cards.
Here are the relevant configs:
stcapp register capability 1/0/0 modem-passthrough
stcapp register capability 1/0/1 modem-passthrough
stcapp register capability 1/0/2 modem-passthrough
stcapp register capability 1/0/3 modem-passthrough
stcapp register capability 1/0/4 modem-passthrough
stcapp register capability 1/0/5 modem-passthrough
stcapp register capability 1/0/6 modem-passthrough
stcapp register capability 1/0/7 modem-passthrough
stcapp register capability 1/0/8 modem-passthrough
stcapp register capability 1/0/9 modem-passthrough
stcapp register capability 1/0/10 modem-passthrough
stcapp register capability 1/0/11 modem-passthrough
stcapp register capability 1/0/12 modem-passthrough
stcapp register capability 1/0/13 modem-passthrough
stcapp register capability 1/0/14 modem-passthrough
stcapp register capability 1/0/15 modem-passthrough
stcapp register capability 1/0/16 modem-passthrough
stcapp register capability 1/0/17 modem-passthrough
stcapp register capability 1/0/18 modem-passthrough
stcapp register capability 1/0/19 modem-passthrough
stcapp register capability 1/0/20 modem-passthrough
stcapp register capability 1/0/21 modem-passthrough
stcapp register capability 1/0/22 modem-passthrough
stcapp register capability 1/0/23 modem-passthrough
stcapp ccm-group 1
stcapp
voice-port 1/0/0
timeouts ringing infinity
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/0/4
voice-port 1/0/5
voice-port 1/0/6
voice-port 1/0/7
voice-port 1/0/8
voice-port 1/0/9
voice-port 1/0/10
voice-port 1/0/11
voice-port 1/0/12
voice-port 1/0/13
voice-port 1/0/14
voice-port 1/0/15
voice-port 1/0/16
voice-port 1/0/17
voice-port 1/0/18
voice-port 1/0/19
voice-port 1/0/20
voice-port 1/0/21
voice-port 1/0/22
voice-port 1/0/23
dial-peer voice 999100 pots
service stcapp
port 1/0/0
dial-peer voice 999101 pots
service stcapp
port 1/0/1
dial-peer voice 999102 pots
service stcapp
port 1/0/2
dial-peer voice 999103 pots
service stcapp
port 1/0/3
dial-peer voice 999104 pots
service stcapp
port 1/0/4
dial-peer voice 999105 pots
service stcapp
port 1/0/5
dial-peer voice 999106 pots
service stcapp
port 1/0/6
dial-peer voice 999107 pots
service stcapp
port 1/0/7
dial-peer voice 999108 pots
service stcapp
port 1/0/8
dial-peer voice 999109 pots
service stcapp
port 1/0/9
dial-peer voice 999110 pots
service stcapp
port 1/0/10
dial-peer voice 999111 pots
service stcapp
port 1/0/11
dial-peer voice 999112 pots
service stcapp
port 1/0/12
dial-peer voice 999113 pots
service stcapp
port 1/0/13
dial-peer voice 999114 pots
service stcapp
port 1/0/14
dial-peer voice 999115 pots
service stcapp
port 1/0/15
dial-peer voice 999116 pots
service stcapp
port 1/0/16
dial-peer voice 999117 pots
service stcapp
port 1/0/17
dial-peer voice 999118 pots
service stcapp
port 1/0/18
dial-peer voice 999119 pots
service stcapp
port 1/0/19
dial-peer voice 999120 pots
service stcapp
port 1/0/20
dial-peer voice 999121 pots
service stcapp
port 1/0/21
dial-peer voice 999122 pots
service stcapp
port 1/0/22
dial-peer voice 999123 pots
service stcapp
port 1/0/23
ephone-dn  61  dual-line
number 2566
label Fax - 2566
description 5137922566
name  Fax
ephone  61
device-security-mode none
mac-address C863.D76B.1407
max-calls-per-button 2
type anl
button  1:61
Inbound call debugs/show commands:
Voice-Gateway#debug voice dialpeer inout
Excerpt:
  Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20061
Voice-Gateway#sh dial-peer voice summary
Excerpt:
20061  pots  up   up             2566$              0                           50/0/61
Voice-Gateway#sh voice port sum | inc 50/0/61
50/0/61         1      efxs     up    up   on-hook  idle     y
50/0/61         2      efxs     up    up   on-hook  idle     y
And ephone status:
ephone-61[60] Mac:C863.D76B.1407
TCP socket:[-1] activeLine:0 UNREGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:0
IP:0.0.0.0 0 Unknown 0  keepalive 0 max_line 0
Preferred Codec: g711ulaw
And ephone debugs:
VoiceGateway#sh debug
EPHONE error debugging is enabled
EPHONE registration debugging is enabled
  for ephones C863.D76B.1407
VoiceGateway#term mon
VoiceGateway#peer_vdb is NULL for DN 69, chan 1 at SkinnyIsPeerNonSCCPpeer_vdb is NULL for DN 69, chan 1 at SkinnyIsPeerNonSCCPpeer_vdb is NULL for DN 40, chan 1 at SkinnyIsPeerNonSCCPpeer_vdb is NULL for DN 47, chan 1 at SkinnyIsPeerNonSCCP  peer_vdb is NULL for DN 47, chan 1 at SkinnyIsPeerNonSCCPpeer_vdb is NULL for DN 40, chan 1 at SkinnyIsPeerNonSCCPpeer_vdb is NULL for DN 47, chan 1 at SkinnyIsPeerNonSCCPpeer_vdb is NULL for DN 69, chan 1 at SkinnyIsPeerNonSCCP
show voice dsp group all:
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 23.8.0
  Max signal/voice channel: 16/16
  Max credits: 240
  num_of_sig_chnls_allocated: 16
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 240, reserved credits: 0
    Signaling channels allocated: 16
    Voice channels allocated: 0
    Credits used: 0
dsp 2:
  Max credits: 240
    Credits used: 0
dsp 5:
  Max credits: 240
    Credits used: 0
dsp 6:
  Max credits: 240
    Credits used: 0
dsp 7:
  Max credits: 240
  num_of_sig_chnls_allocated: 8
    Signaling channels allocated: 8
    Credits used: 0
dsp 8:
  Max credits: 240
  num_of_sig_chnls_allocated: 0
    Signaling channels allocated: 0
    Credits used: 0
DSP groups on slot 1:
DSP groups on slot 2:
This command is not applicable to slot 2
  0 DSP resource allocation failure
Are the gateways VG224 or VG204?
I've a network with 15 VG204's and the only way I can get them to register was to do a #erase startup-config #reload
I then have a script I push to the VG204 and it registers with CME fine. I'll have access to all the info latter if it helps?
Lee
Lee, the ports are all on an EVM-HD-8FXS/DID with EM-HDA-8FXS daughter cards.  As far as I know there are no other VGs on site.
Hi Phil,
Try removing all your stcapp configuration and just create a dial-peer voice pots XXX and place the port command in it, along with the extension number.
example.
dial-peer voice pots 999100
description # Analogue Phone 1 #
destination-pattern 2566$
port 1/0/1
As long as your translation patterns are correct an imcoming call will ring the analogue device connected to port 1/0/1
stcapp allows analogue ports to be regsitered to a call control server, Ive only seen this with CUCM, and with failover to SRST/CME in both cases you do have to add extra commands. But give the above a try and should be right to make and receive calls.
Cheers
Ben
Please rate is this post is useful
Re: Unregistered FXS port in CME
Thanks Ben, I'll give it a shot.  I thought the SCCP config may be the culprit but with so many other working devices it didn't seem likely.  This is definitely the first time I've seen a CME deployment running SCCP on analog devices though so I look forward to testing plain old H.323 either tonight or tomorrow.  I'll definitely report back and let you know how it goes though.
Any idea how to figure out which physical analog port this device is attached to?  The only reference I seem to have is ephone-dn, ephone, and a virtual dial-peer.
Thanks again!
Hi Phil,
Did you check if the CME Phone capacity got exhausted? I mean, CME supports certain amount of Phones based on the hardware platform, maybe is that you just need to increase the "max-ephone" on telephony-service, or you just ran out of ephone "tags" on CME.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Phone capacity is ok.  I ended up using a different port on the voice gateway so I'm still not sure what was going on with the original port.  I guess I may never know!
Thanks for all the help though.
1062
