Community Member
Unregistered Phones
UCM 7.1.20000-2
I just recently started to have several phones go unregistered.  I phones are on seperate switches.  I can unplug POE phones and reconnect them and they register just fine.  What is the best way to troubleshoot or isolate the problem.  Is there a known bug.  The phones impacted are SCCP 7940 phones with the current firmware.
1 REPLY
Re: Unregistered Phones
By default every phone will send a keepalive every 30 seconds and will receive a keepalive ack from primary CUCM. If the phone misses 3 keepalive acks (90 seconds) the TCP connection will be reset which can cause it to unregister and same thing is CUCM misses 2 keepalives (60 seconds).  So first thing is to check from callmanager on the reason for device unregistered (you will see stationinit , keepalive timeout reason cdoe 13 etc). If you deterine the issue being caused because of the keepalive losses, then the next thing is to get packet captures both from callmanager and the Phone expeirencing the issue to make sure if these are sending keepalives/acks as they should and are getting lost in the network or the phoen itself stops to send keepalives.
Lakshmi
204
