unsupported operation
Hi all,
I have received following debug from isdn q931. as any calls couldnt be established.
what is the problem ? I have as5350 gateway.
Protocol Profile = Remote Operations Protocol
0xA13702029FBE060A2B0C028853033601010130250A010404200014080008040003000000000000000000000000000000000000000000000000
Component = Invoke component, Unsupported operation
*Mar  2 19:38:53.328: ISDN Se3/1:15 **ERROR**: isdnAsn1Component: ERROR
*Mar  2 19:38:53.328: ISDN Se3/1:15 **ERROR**: process_facility_supp_services: Decode of facility IE operation failed
*Mar  2 19:38:53.328: ISDN Se3/1:15 **ERROR**: CCPRI_Go: call id 0x0 event 0xD No ccb Source->HOST
*Mar  2 19:38:59.772: ISDN Se3/1:15 Q931: RX <- SETUP pd = 8  callref = 0x602B
  • IP Telephony
Hall of Fame Super Gold
Send the complete debug, not just the portion that you think is relevant.
Cisco#
*Mar  2 23:08:19.319: ISDN Se3/1:15 Q931: RX <- SETUP pd = 8  callref = 0x60B0
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98398
Exclusive, Channel 24
Facility i = 0x91A1130202A4A802010F300A0201010A0101A1028100
0xA1130202A4A802010F300A0201010A0101A1028100
Invoke Id = 42152
Operation = Diversion Leg2
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x0083, '02188140143'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '9730003'
Plan:ISDN, Type:Unknown
*Mar  2 23:08:19.323: ISDN Se3/1:15 Q931: extract_redirect_orig_called_ie: IE type redirecting num none reason 15 cnt 1 plan -1 t
ype 0 pres 1
*Mar  2 23:08:19.327: ISDN Se3/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 02188140143
*Mar  2 23:08:19.327: ISDN Se3/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 9730003
*Mar  2 23:08:19.327: ISDN Se3/1:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xE0B0
*Mar  2 23:08:19.327: ISDN Se3/0:15 Q931: TX -> SETUP pd = 8  callref = 0x01AF
Sending Complete
Standard = CCITT
Channel ID i = 0xA9839F
Exclusive, Channel 31
Invoke Id = 42152
*Mar  2 23:08:23.271: ISDN Se3/1:15 Q931: RX <- FACILITY pd = 8  callref = N/A
Facility i = 0x91A1370202A4A9060A2B0C028853033601010130250A0104042000140800080400030000000000000000000000000000000000000000000000
00
0xA1370202A4A9060A2B0C028853033601010130250A010404200014080008040003000000000000000000000000000000000000000000000000
*Mar  2 23:08:23.271: ISDN Se3/1:15 **ERROR**: isdnAsn1Component: ERROR
*Mar  2 23:08:23.275: ISDN Se3/1:15 **ERROR**: process_facility_supp_services: Decode of facility IE operation failed
*Mar  2 23:08:23.275: ISDN Se3/1:15 **ERROR**: CCPRI_Go: call id 0x0 event 0xD No ccb Source->HOST
*Mar  2 23:08:23.327: ISDN Se3/0:15 Q931: TX -> SETUP pd = 8  callref = 0x01AF
Try
interface Se3/0:15
no isdn outgoing facility.
However there is to see to what are you conencting to, and what these facilities are actually trying to do.
Blue
Would it be possible to send us full configuration of the router.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Current configuration : 7642 bytes
version 12.4
hostname Cisco
boot-start-marker
no boot startup-test
boot-end-marker
enable secret 5 $1$GQvH$/7LADpw5r7YQrsXB3ARyS.
enable password 1234
resource-pool disable
no aaa new-model
resource policy
syscon address 192.168.0.1 123
syscon shelf-id 0
spe default-firmware spe-firmware-1
ip cef
isdn switch-type primary-net5
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
modem passthrough nse codec g711alaw
sip
  registrar server
  no call service stop
voice translation-rule 1
rule 1 /^1111/ //
voice translation-profile profile1
translate called 1
username ivr password 7 10671F0B54
controller E1 3/0
pri-group timeslots 1-31
cablelength medium
controller E1 3/1
cablelength medium
translation-rule 1
interface GigabitEthernet0/0
ip address 10.142.x.x 255.255.255.248
duplex full
speed auto
negotiation auto
no cdp enable
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
negotiation auto
no cdp enable
interface Serial0/0
no ip address
shutdown
clock rate 2000000
no dce-terminal-timing-enable
no fair-queue
no cdp enable
interface Serial0/1
no ip address
shutdown
clock rate 2000000
no cdp enable
interface Serial3/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn not-end-to-end 64
isdn incoming-voice modem 64
isdn T310 60000
isdn send-alerting
isdn sending-complete
no isdn outgoing ie facility
no isdn outgoing display-ie
no cdp enable
interface Serial3/1:15
no ip address
encapsulation hdlc
isdn T310 60000
no cdp enable
interface Async1/00
no ip address
encapsulation slip
interface Async1/01
no ip address
encapsulation slip
interface Async1/02
no ip address
encapsulation slip
interface Async1/03
no ip address
encapsulation slip
interface Async1/04
no ip address
encapsulation slip
interface Async1/05
no ip address
encapsulation slip
interface Async1/06
no ip address
encapsulation slip
interface Async1/07
no ip address
encapsulation slip
interface Async1/08
no ip address
encapsulation slip
interface Async1/09
no ip address
encapsulation slip
interface Async1/10
no ip address
encapsulation slip
interface Async1/11
no ip address
encapsulation slip
interface Async1/12
no ip address
encapsulation slip
interface Async1/13
no ip address
encapsulation slip
interface Async1/14
no ip address
encapsulation slip
interface Async1/15
no ip address
encapsulation slip
interface Async1/16
no ip address
encapsulation slip
interface Async1/17
no ip address
encapsulation slip
interface Async1/18
no ip address
encapsulation slip
interface Async1/19
no ip address
encapsulation slip
interface Async1/20
no ip address
encapsulation slip
interface Async1/21
no ip address
encapsulation slip
interface Async1/22
no ip address
encapsulation slip
interface Async1/23
no ip address
encapsulation slip
interface Async1/24
no ip address
encapsulation slip
interface Async1/25
no ip address
encapsulation slip
interface Async1/26
no ip address
encapsulation slip
interface Async1/27
no ip address
encapsulation slip
interface Async1/28
no ip address
encapsulation slip
interface Async1/29
no ip address
encapsulation slip
interface Async1/30
no ip address
encapsulation slip
interface Async1/31
no ip address
encapsulation slip
interface Async1/32
no ip address
encapsulation slip
interface Async1/33
no ip address
encapsulation slip
interface Async1/34
no ip address
encapsulation slip
interface Async1/35
no ip address
encapsulation slip
interface Async1/36
no ip address
encapsulation slip
interface Async1/37
no ip address
encapsulation slip
interface Async1/38
no ip address
encapsulation slip
interface Async1/39
no ip address
encapsulation slip
interface Async1/40
no ip address
encapsulation slip
interface Async1/41
no ip address
encapsulation slip
interface Async1/42
no ip address
encapsulation slip
interface Async1/43
no ip address
encapsulation slip
interface Async1/44
no ip address
encapsulation slip
interface Async1/45
no ip address
encapsulation slip
interface Async1/46
no ip address
encapsulation slip
interface Async1/47
no ip address
encapsulation slip
interface Async1/48
no ip address
encapsulation slip
interface Async1/49
no ip address
encapsulation slip
interface Async1/50
no ip address
encapsulation slip
interface Async1/51
no ip address
encapsulation slip
interface Async1/52
no ip address
encapsulation slip
interface Async1/53
no ip address
encapsulation slip
interface Async1/54
no ip address
encapsulation slip
interface Async1/55
no ip address
encapsulation slip
interface Async1/56
no ip address
encapsulation slip
interface Async1/57
no ip address
encapsulation slip
interface Async1/58
no ip address
encapsulation slip
interface Async1/59
no ip address
encapsulation slip
interface Group-Async0
no ip address
encapsulation slip
no group-range
interface Group-Async1
physical-layer async
no ip address
encapsulation slip
interface Group-Async21
no ip address
encapsulation slip
no ip http server
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
no cdp run
control-plane
voice-port 3/0:D
disc_pi_off
echo-cancel coverage 24
no non-linear
playout-delay mode fixed
no comfort-noise
cptone DE
voice-port 3/1:D
disc_pi_off
no non-linear
no comfort-noise
cptone DE
dial-peer voice 2 pots
translation-profile outgoing profile1
service session
shutdown
destination-pattern .+
no digit-strip
direct-inward-dial
port 3/0:D
forward-digits all
dial-peer voice 3 pots
numbering-type unknown
service session
incoming called-number .+
no digit-strip
direct-inward-dial
port 3/1:D
forward-digits all
dial-peer voice 12 voip
service session
session protocol sipv2
session target ipv4:10.142.x.x
session transport udp
dtmf-relay rtp-nte
codec g711alaw
no vad
gateway
timer receive-rtp 1200
sip-ua
credentials username 1111 password 075E701D1F realm pendar
authentication username 1111 password 08701D1F58
no remote-party-id
no redirection
srv version 1
retry register 10
timers register 100
registrar ipv4:10.142.x.x expires 60
sip-server ipv4:10.142.x.x
ss7 mtp2-variant Bellcore 0
ss7 mtp2-variant Bellcore 1
ss7 mtp2-variant Bellcore 2
ss7 mtp2-variant Bellcore 3
line con 0
password 7 065F58731D165841
logging synchronous
login local
line aux 0
line vty 0 4
password 1234
login
line 1/00 1/59
modem InOut
scheduler allocate 10000 400
no process cpu extended
no process cpu autoprofile hog
end
2084
