Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Untagged port connecting to PC with COS field
Hi, all
I am facing with a little curious question in terms of COS on untagged port.
My question is that how COS field can be marked in untagged port if i command "switchport port extend cos 1"
generally we can control COS field in accordance with tagged port as known VLAN. but For PC, it works on unttaged port.
There is no COS field in untagged packet. does anybody know about that ?
The following configuration are what I wanna do;
1. VLAN 12 for PC, Data traffic
2. VLAN 200 for IP phone, voice taffic (COS 3 : voice control, COS 5 : voice packet on default behavior)
3. Needs to mark COS 1 for data taffice
Switch --------- IP phone -------- PC
## configuration ##
switchport mode access vlan 12
switchport voice vlan 200
mls qos cos trust
Re: Untagged port connecting to PC with COS field
Multi-VLAN access ports are supported by all Cisco Catalyst switches. All data devices
typically reside on data VLANs in the traditional switched scenario. A separate voice VLAN
may be needed when combining the voice network into the data network. Cisco Catalyst
switches using Catalyst Oerating System refer to the voice VLAN as the auxiliary VLAN
You can implement multiple VLANs on the same port by configuring an access port. A tagging
mechanism distinguishes among VLANs on the same port. 802.1Q is the IEEE standard for
tagging frames with a VLAN ID number. The IP phone sends tagged 802.1Q frames. The PC
sends untagged frames and the switch puts the frame into the configured access VLAN. When
the switch receives a frame from the network destined for the PC, it removes the access VLAN
tag before forwarding the untagged frame to the PC
i think this information has answered your question
good luck
please, if helpful rate
Thanks a lot, marwanshawi,
I meant COS field. If you mark COS 5 for voice,and COS 2 for Data, how does switch fill cos 2 in untagged packet ?
It makes sense Voice packet, because Voice will be tagged with VLAN ID. but For data traffice,PC, there is no cos field, because Data traffice will be unttagged.
could you explain about that ?
In order to avoid this, remove the trunk configuration and keep the voice and access VLAN configured along
with Quality of Service (QoS). Technically, it is still a trunk, but it is called a Multi-VLAN Access Port
(MVAP). Because voice and data traffic can travel through the same port, you should specify a different
VLAN for each type of traffic. You can configure a switch port to forward voice and data traffic on different
VLANs. Configure IP phone ports with a voice VLAN configuration. This configuration creates a pseudo
trunk, but does not require you to manually prune the unnecessary VLANs
because Technically, it is still a trunk
it can have cos field
i think now more clear :)
366
