Unwanted Automated fax tones to user on a 7941 ip phone
DerekM
I have a user that is getting annoying automated faxes on her phone twice a day. How can I stop these automated faxes to this one particular number on a cluster. It is only 1 user. CCM V4.2(3) MGCP
5 Replies 5
dhccoid.com
Does the phone display where the fax call came from?
No the phone does not display number otherwise I would advise customer to just fax back with a message requesting to stop sending to this number?
Rob Huffman
Hi Derek,
There is no way to block these calls based on CLID using a MGCP Gateway :( When one of these Fax calls comes through ask this user to Transfer the call to a Fax line. This way you can get the Header info from the Fax Page and contact the offending company on her behalf.
Hope this helps!
Rob
Many thanks Rob,was not sure if this would work.
Hi Derek,
You are most welcome my friend :)
Take care,
Rob
