Community Member
Update CRA 3.1 to 4.0
Hello
we are planning a CRA update from 3.1(2) to 4.0(5a). We got three CDs from Cisco and a card with a Product Authorization Key.
Do we have to upgrade our 3.1 License files and if yes where and how can we do that?
Thanks for your help
Reto
1 REPLY
Gold
Re: Update CRA 3.1 to 4.0
I think that you you have got to obtain a license file from the PAK code. If that code is for the CRS version 4, I think that you won't have problems.
First of all, check the documentation to know if you have to do any special process to upgrade from version 3.1(2) to version 4.0(5a).
Hope this helps,
Juan Luis
111
