Update Phone Button Template with BAT
Hello
I try to update the Phone Button Template with BAT on my Callmanager 4.2(3).
However I can not find an entry in BAT to update the Phone Button Template.
Has anyone an idea how I can update the Phone Button Template with BAT?
Thanks Reto
Re: Update Phone Button Template with BAT
I guess you should be able to modify the phone button template from "Modify Phone Template" page. PLease check this following link
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00806cce16.html#wp1353231
Hall of Fame Super Red
Hi Reto,
This is one of the Phone settings that cannot be changed via BAT (See Below). You can however update an existing Phone Button Template via Device>Device Settings>Phone Button Template. When you select an existing Template CCM will show you how many devices currently use it. You can modify the Template and push it out to the phones that use it.
Use BAT phone templates to define the common phone attributes to add a group of new phones. Prior to creating the template, make sure phone settings such as device pool, location, calling search space,*** button template and softkey templates have already been configured in Cisco CallManager Administration. You cannot create new settings in BAT.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080533366.html
Hope this helps!
Rob
172
