Update TFTP Address on IP Communicator
Hi Voice team, i change the CUCM on my company to version 9.1.
I had to change the ip address, the problem is that now I have more than 100 ip communicator, how do I dynamically change the TFTP address that is registered?
Thiago
2 ACCEPTED SOLUTIONS
Re: Update TFTP Address on IP Communicator
Hi.
The windows registry key mentioned by Chris is HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems Inc.\Communicator
TFTPServer1 (the ip address is written in decimal or hexadecimal)
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
VIP Super Bronze
tftfp1: 56022f0a
tftp2: 57022f0a
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hall of Fame Super Silver
It is stored in the registry, so if you can push the registry update it would be the easiest, assuming you are not using default and pulling it from DHCP scope.
HTH,
Chris
Hi.
Carlo
VIP Super Bronze
Just to add to excellent suggestions by Chris and Carlo (+5 guys), the hexadecimal values is read backwards..
eg..here is the hex value of my tftp server in the registry
e01fa8c0
e0=224
1f=31
a8=168
c0=192
so the ip will be
192.168.31.224
I found this parameter in hex, but how I put the IP of the new CUCM?
VIP Super Bronze
You need to convert your ip to hexadecimal...You can use this link to convert hex to dec or dec to hex
http://www.statman.info/conversions/hexadecimal.html
I made the conversion from my new ip 1047286 and the hex is ffaf6, i put on TFTP parameter, but the ip communicator
did not change the address.
VIP Super Bronze
That conversion is wrong..can you confirm that your ip address is 10.4.72.86? I will do the conversion for you
the ip address is 10.47.2.86 TFTP1 and 10.47.2.87 TFTP2
VIP Super Bronze
tftfp1: 56022f0a
tftp2: 57022f0a
Thanks, after put this,i need to reboot my windows?
VIP Super Bronze
Not really..I am running Windows 7 and I didnt need to restart my mahcine. Ensure you exit the IP communicator and start it again, if it doesnt still work, try and restart it
It works only on TFTP 2, on TFTP 1 still the old ip address on IP communicator
VIP Super Bronze
Ensure you have entered it correctly...If it works on one, it has to work on the other--or restart the pc
Thanks a lot voice team.
VIP Super Bronze
Wao! Thiago not a even a single star for all my troubles!
Sorry, i forgot...
You help me a lot.
I realized I have some computers that have IP communicator but does not have the option TftpServer1 and TftpServer2 Communicator, I tried to create the registry but did not work.
Hi Thiago.
In that case you should change two registry keys.
Put AlternateTftp key to 1 (the path is the same that i specified above)
and modify TftpServer value as above
Carlo
Hi.
I would also add that only IP Communicator should be resterted  to make valid registry changes both on Win7 and XP.
Carlo
Thanks, i will make the test later.
Hall of Fame Super Red
Great work to all involved here (+5) !! An extra +5 for Deji for going above and beyond
to help others here @ CSC
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
..and +5 to you my friend because you have always a good word for everyone here : )
Carlo
1016
