Updating phone firmware - CCM 4.02
where can I find a detailed/step-by-step doc. showing phone firmware load upgrade procedures for the CCM 4.02 cluster?
The phone types: 7940, 7941, 7960, 7961, 7936, 7906, 7914
Re: Updating phone firmware - CCM 4.02
download the .exe and run it on the TFTP servers, reset phones.
README files contains install instructions
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi Fureya,
Following link will take you to the download page for cmterm-7940-7960-sccp.8-0-8.exe. On that page look below where is says Release Information. There you can find the readme file.
Please be aware that the link should be used as an example; pick the correct firmware version for your CM version and phone model from the actual Voice Downloads page.
http://tools.cisco.com/support/downloads/go/IPCheck.x?defAdv=N&sftAdv=N&filename=cmterm-7940-7960-sccp.8-0-8.exe&advUrl=null&defInd=N&mdfid=268437897&sftType=Skinny+Client+Control+Protocol+(SCCP)+Software&optPlat=&nodecount=7&relVer=8.0(8)&md5=f129ad7d9127bc1e94e32e04b9eff1b2&modifmdfid=268437897&imname=&hybrid=Y&imst=N&modelName=Cisco+Unified+IP+Phone+7940G&treeMdfId=278875240&treeName=Voice+and+Unified+Communications&edesignator=null&nodecount=7&fsd=&wc=N&hasfsd=N
Mehmet
228
