Community Member
Updating Unity Users Remotely
I am currently working on a way of importing users into unity from a remote machine. I can import the user accounts in to active directory no problem. What I cannot find is the information that is assigned to the users. Is this stored within SQL or in another location?
1 REPLY
Re: Updating Unity Users Remotely
the information from the subscriber is located at the subscriber table within the unity DB.
you need to create the subscriber before you try to look information within unity
java
if this helps, please rate
java
www.cisco.com/go/pdi
111
