Updating UserID field on enduser table on CUCM via sql
I have a cucm cluster with local users (something around 1500 users) where the cucm users and the active directory users are complitelly different.
I have an excel file whitch have the active directory users and the cucm users respectively and I want to run an sql update command to update the users on the cucm to be the same as the active directory users and then make a LDAP sync on the cucm.
Someone can help me with the set sql update commant for this issue ?
Liran.
Re: Updating UserID field on enduser table on CUCM via sql
You could do this using AXL.
There is an updateUser Element
(https://developer.cisco.com/site/tech/communication-collaboration/management/axl/develop-and-test/documentation/latest-version/axl-soap.gsp)
You could program an application that reads the information from the excel sheet or a csv and sends a request for every user to CUCM.
Unfortunately I don't have a working example for this available.
Also have a look at the developer site:
https://developer.cisco.com/site/tech/communication-collaboration/management/axl/axl/
The XML-Request should look like this:
http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/8.5">
         enduser1
         newenduser1
Thank you for the response but I think that I didnt understand waht do you mean.
I know that I can do it with simple command for each user , so I preffer to do it on this way.
Does someone knows the exact command for update the userid ?
BR,
Liran.
I have a sample perl script.
It is not exacly what you are looking for but can easily be changed.
It changes Call Forward All on a number of lines.
Therefor it reads a CSV file with 2 collums (line and CFA destination); generates a AXL request; sends it to CUCM.
It could be modified to change userid. The AXL request you will need is the one above.
Find the script here:
http://www.file-upload.net/download-8521718/Scripting.zip.html
Thanks for your effort.
I will try this and update you  .
Thank you ,
Liran.
Finally I used the next command:
run sql UPDATE enduser SET userid='New_UserID' WHERE userid='Old_UserID'
Liran.
Liran,
Liran,
How did you use this command for bulk updating the enduser table? Were you able to call the user ID variables from a CSV, or other, file?
/R
873
