Updating Users Associated with Line
trying to update this information on the lines with BAT.
How can this be done if at all?
This is for presence.
Silver
Re: Updating Users Associated with Line
Check the bug: CSCsk86877: Comm Mgr BAT doesnt have setting for Usrs Associated with Line ability
Hope this doc helps.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/bulk-administration-tool/110967-bat-00.html#line
Andrew.
make the csv file through Bat.xlt file with the existing configuration on the lines. Also add the extra information that you want to add on those lines..
Now use BAT to insert those phones again and while inseting those phones, there will be one option..
:Overwrite existing information"
check that. This will overwrite the existing information for those lines and you will be able to add information.
256
