Upgarding CCM 4.0 To 6.12
What's the best way to do this upgrade? To first upgrade to CCM 4.13, and then use DMA and go to 6.12? Or, upgrade to 6.11, using DMA, and then upgrade that version to 6.12?
Currently, 2 server cluster, 4.02, MCS-7815 servers, going to new servers.
Thanks!
1 REPLY
Re: Upgarding CCM 4.0 To 6.12
from 4.1(3) you can go to 6.1(2) directly
Table 4 Supported Cisco Unified Communications Manager Upgrades for Release 6.x and Release 7.x
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp40122
java
if this helps, please rate
java
www.cisco.com/go/pdi
100
